Put new top end on new plugs cleaned carbs running Klotz 32:1 When it is cold runs like shit but warns up runs like a champ. And won't really idle O yea when I first start it when it is cold it revs up really high What is the problem
Take this quick quiz for us...
Did it pass a leak down test?
What carbs are you running?
What jets are installed (pilot & main)?
What are all of the modifications?
What is your elevation?
What is the tempurature? (my banshee runs a little hard until it warms up too, its part of being a cold engine)
With out knowing any of this, it sounds like a possible lean condition. You say you rebuilt the top end so I want to make sure you performed a leakdown test so that we can be sure its not drawing air from a leak somewhere. Next I think we should look at jetting. Post up!
Try adjusting air/fuel screw on carb, see if it idles better. Are ur carbs synced?
Edited by acroadam
