finishers13146 Posted March 2, 2011 Report Posted March 2, 2011 i just installed a high flow water pump and it doesnt seem to be working this is whats happnen there is a little rubber hose that goes from the top of the head to the radiator that gets hot first then the radiator gets hot from the top then to the bottom but when the radiator is completely hot i cant put my hands on it the water pump housing and the hoses that go from the head to the radiator and from the water pump to the radiator are ice cold? can some one start there banshee and feel the hoses and see if yours does the same thing thanks Quote
Phelps Posted March 2, 2011 Report Posted March 2, 2011 did you put the pin under the pump gear back in? Quote
finishers13146 Posted March 2, 2011 Author Report Posted March 2, 2011 did you put the pin under the pump gear back in? sure did Quote
sleeper06 Posted March 2, 2011 Report Posted March 2, 2011 leave the cap of rad off start bike,look n see if water is flowin when yopu hit the gas Quote
finishers13146 Posted March 3, 2011 Author Report Posted March 3, 2011 leave the cap of rad off start bike,look n see if water is flowin when yopu hit the gas i cant really tell the way it vibrates Quote
someone82 Posted March 3, 2011 Report Posted March 3, 2011 When I first got my banshee I discovered that the pin didn't seat right on the drive gear and it rounded out the gear. It would have enough friction to spin at idle but once the motor would spin up it would stop pumping. Something to think about. Quote
