i just installed a high flow water pump and it doesnt seem to be working this is whats happnen there is a little rubber hose that goes from the top of the head to the radiator that gets hot first then the radiator gets hot from the top then to the bottom but when the radiator is completely hot i cant put my hands on it the water pump housing and the hoses that go from the head to the radiator and from the water pump to the radiator are ice cold? can some one start there banshee and feel the hoses and see if yours does the same thing thanks
When I first got my banshee I discovered that the pin didn't seat right on the drive gear and it rounded out the gear. It would have enough friction to spin at idle but once the motor would spin up it would stop pumping. Something to think about.
