CFH87 Posted February 27, 2011 Report Posted February 27, 2011 I'm going to be rebuilding the motor on my banshee and was going with a dune port from kevin at herrjugs and was wondering what I would need to hold that power? Would upgrading the plates and going to hd springs be good enough? I'll be running fmf pipes, stock carbs, timing plate, and k & n pod filters. Quote
beebs Posted February 27, 2011 Report Posted February 27, 2011 If you're getting the motor work done at HJR just get the clutch kit Kevin sells. It will hold no problem and you might as well go with a complete clutch kit to go with the fresh motor. Quote
CFH87 Posted February 27, 2011 Author Report Posted February 27, 2011 Any idea on cost of that kit? Quote
beebs Posted February 28, 2011 Report Posted February 28, 2011 Around $84 and comes with steel plates, friction plates, and springs. I run the same with a little more motor. Works well. Quote
CFH87 Posted February 28, 2011 Author Report Posted February 28, 2011 I hope it holds up because I know with all that power I'll be beating the snot out of it lol Quote
