I just took a engine apart that had a bad one........IT would not come out.......I had to split the cases and dremel the pusher because the rod had gouged the pusher to the point of being deformed......so thats one sign......it wont turn or come out...
Where is it located behind the clutch basket
I managed to get one out that had mushroomed. I took out the clutch actuator arm on the top left side of the motor. I used a dremel tool with a flexible extension. I was able to grind down the mushroomed area. Then I used a stick magnet to retrieve the actuator out of the right hand side of the motor. Took about an hour and a little bit of cussing but much easier than pulling the motor and splitting the cases.
Thanks for the help hopefully it's just an adjustment issue
