Here's my problem my shee is hard to start once it's started it sounds like my left cylinder is missing I pulled the airbox and part of the boot from the air box to the carb wasent all the way on would this lean it out and cause the misfire
Mosy likely no. Check ur spark, well go from there. It should be a consistent bright blue spark on both cylinders. If its running lean, which I don't think it is, it would revv itself up and wouldn't kill when u hit the kill switch. Start with the spark....
