what are the benefits 2 the T.O.R.S delete?? is there really any gain on power/fuel efficiency?? or is it just the convenience of having more room around the motor and a little less weight??
Its neither..................................the T.O.R.S. system will eventually have you chasing a problem........it is known to cause problems with your shee running right............................................like sputter..not revving out............................etc.............................it is design to protect the engine from overreving....................................he.nce the name Throttle Over Ride System
The benefit is you will not have any issues as above with removing the tors...its worthless and takes up a shitload of space.................................................
so an added bonus is the more room and you have the peace of mind of knowing something is actually wrong when its not running right...........................................Its the first thing i would do to any shee
The tors is not wort anything to anyone here............................................so toss it in the scrapyard
removing the tors makes it a lot easyer to sync you carbs and tune it
TORS can be DISABLED by just unplugging the little black box under the left side of the fuel tank next to the coil, nothing else needs to be done to disable it. The delete kits get rid of the funky carb tops and make it easier to work on the carbs.
