Is the squish suppose to be the same on both cylinders ? or can there be a difference ?
also i read where the squish should be measured in mm
and the .4mm-.5mm is good for bottom end and .6mm to .9mm for topend this ranges from .022 to .036 tho but i see people always saying to run .040 -.050 which is really big in the 4 stroke world.
What motor is this about?
What are you wanting and what does yours check out at right now?
Details please.
They should be basically spot on with one an other or there is an underlying issue.
I just buttoned my motor up yesterday and with different domes also.
Squish checked out at .042. :cheers:
