OK if i had two motors,one with a 4mil and the other stock crank and both having the same topend and domes will the 4mil compression be higher ?
also i had 155 psi with 19cc domes and installed 17cc and it only went to 162psi...to me that doesnt seem right.....cylinders are drag ported.
elevation will have a big play on compression and dome size,the higher the elev the smaller the dome,I think 5000 ft above sea level and a 15cc dome is like 145 compression,going off a dome size chart.
