coon Posted August 14, 2010 Report Posted August 14, 2010 hello banshee hq im am new to the site and to banshees i just picked up a 97 banshee with paperwork i am the 3rd owner and it hasnt been beat on at all..when i got it it wouldnt start unless u kicked forever and choked it so i cleaned the nasty carbs still wouldnt idle nor start easy...did some reading on the tors system jumped the wire and now the bike idles fine and runs great but i cant get it started easy by kicking if i spray carb cleaner in the carbs jus a tad bit it fires one kick and runs all day keeps firing one kick even when cold its just when i park it for night and goto ride the next day i have to spary a lil carb cleaner again and it kicks over one kick all day i dont really get it any help would be awesome as i am starting to fall in love with this machine! Quote
Larry's Shee Posted August 14, 2010 Report Posted August 14, 2010 Welcome to BHQ !! Try cleaning carbs again, disasembleing them ONE at a time. Be sure to reattach choke cross over tube. Are you sure you got the float bowls on the correct carb? They are different !! Quote
toytech Posted August 14, 2010 Report Posted August 14, 2010 (edited) Welcome to BHQ like Larry's shee said clean the carbs again, varnish gets built up and sometimes takes 2 or 3 cleans to get out. also make sure the slides are in sync. and make sure the filter is clean and oiled properly and sealed to the air box with some grease. you've been bitten by the Banshee bug, it's a great feeling two stroke twins rule Edited August 14, 2010 by toytech Quote
coon Posted August 14, 2010 Author Report Posted August 14, 2010 Welcome to BHQ like Larry's shee said clean the carbs again, varnish gets built up and sometimes takes 2 or 3 cleans to get out. also make sure the slides are in sync. and make sure the filter is clean and oiled properly and sealed to the air box with some grease. you've been bitten by the Banshee bug, it's a great feeling two stroke twins rule Thanks for all the quick replys i am going to clean the carbs again try the air filter cause mine is shot and im also gunna re gap my plugs cause the old owner has them gapped to 35 thanks again ill be sticking around banshee hq:) Quote
coon Posted August 14, 2010 Author Report Posted August 14, 2010 now i have a new problem just went to go riding and my shee wouldnt start when i tried the fuild again so i pullled the plug and im not getting any spark it is pissing me off cuase i just had it running this morning fine any ideas where i should start first? i tired the plug on a differnt wheeler and it sparks so i know my plugs are good Quote
