are there longer idle screws for the banshee carbs to allow more idle adjustment up? my idle is turned all the way in and still seems pretty low. tors has been removed. top end is fresh and leakdown test is good.
Did you grind the adjustment down before installing the new adj screws??
X2, grind it down almost flush (leave 2MM or so) to the side of the carb, then you will have plenty of idle adjustment.
i bought the bike the way it is, what do i grind the threaded hole on the carb?
back out the idle adjustment screw and lock nut...grind that down some more....it needs to be ground down to have more adjustment......it is the one that the screw is in....
Here are some pics man.
Pull the slides out and stuff a rag all the way through to catch the shavings. Then blow them out with compressed air afterwards!
You can use the grinding burr as shown, or a file or what ever you have, just take it down some so there is still some meat left for the nut to seat on.
Take your time, there is no hurry.
Your suppose to do this before you drill and tap the holes ( i know you didn't install them) so you "might" have to clean up the threads lightly after. Its pretty soft aluminum so its easy.
right so i am grinding down the threaded hole on the carb that the idle screw and locknut thread into. not grind down the screw right?
