banshee9090 Posted May 12, 2010 Report Posted May 12, 2010 hi I hoop you guys all ok ! before when I m racing at the dyne I use to start accelerate with 2nd gear then 3rd with stuck engine now I got build 4mill engine ,I like to start accelerate with 3rd gear because it is faster ! what do you guys think is it possible to do that every time ? thanks Quote
baker Posted May 12, 2010 Report Posted May 12, 2010 so you like buying clutches? ive used the second gear start in many harescrambles but never third, i dont know how good that would work, seems to me you would have to use alot of clutching to take off without flipping over if your holding it wide open to launch in third. Quote
Larry's Shee Posted May 12, 2010 Report Posted May 12, 2010 You might want to go one tooth larger on the front sprocket , (gear) , no offense but translation programs are kid of funny. Welcome to BHQ !! Quote
locogato11283 Posted May 12, 2010 Report Posted May 12, 2010 3rd gear launches are not particularly a good idea due to third gear not being as strong as second gear. the chances of you breaking 3rd are a lot higher than you breaking 2nd. Quote
banshee9090 Posted May 12, 2010 Author Report Posted May 12, 2010 3rd gear launches are not particularly a good idea due to third gear not being as strong as second gear. the chances of you breaking 3rd are a lot higher than you breaking 2nd. I really appreciate all the help you've given me guys thanks Quote
