banshee9090 Posted April 27, 2010 Report Posted April 27, 2010 Yesterday I have done my New rebuild shee engine, hot rod 4mill crank shaft long rod with 2 vertex piston size 250, 22cc cut domes , cool head pro design ,toomey t-6 exhaust, 2 K&N w/out the airbox , stuck carb.,290 main jet ,long needle the elevation 1968 fit What you guys suggest exercising the new engine now ? Quote
banshee9090 Posted April 27, 2010 Author Report Posted April 27, 2010 Yesterday I have done my New rebuild shee engine, hot rod 4mill crank shaft long rod with 2 vertex piston size 250, 22cc cut domes , cool head pro design ,toomey t-6 exhaust, 2 K&N w/out the airbox , stuck carb.,290 main jet ,long needle the elevation 1968 fit What you guys suggest exercising the new engine now ? suggesting about 1-permix oil yamalub 2- speed . thanks Quote
rdzbangshee Posted April 27, 2010 Report Posted April 27, 2010 suggesting about 1-permix oil yamalub 2- speed . thanks i use yamalube 2s it burnes 50% cleaner than the yamalube R Quote
banshee9090 Posted April 28, 2010 Author Report Posted April 28, 2010 I would suggest the following exercise: 10 laps around the track 100 push ups 100 sit ups and 2 set of 8 reps on all arm and leg machine. you need to get this banshee fit lol THANKS FOR THE ADVICE !!!! Quote
dajogejr Posted April 28, 2010 Report Posted April 28, 2010 I would go a little richer on the mains just to be safe.. Otherwise...I think you're spot on... Why 22cc domes may I ask? Quote
banshee9090 Posted April 28, 2010 Author Report Posted April 28, 2010 I would go a little richer on the mains just to be safe.. Otherwise...I think you're spot on... Why 22cc domes may I ask? Thanks for feed back If I m not wrong 22cc dooms for low pressure therefore more cool for the engine! Quote
