I got i 6 speed override that won't shift unless you go slow so i took it apart and two of the dog ears are welded then grind on a slant.
should there be any welding on the ears of a 6 speed override ??
Maybe the welding is the strengthen the dogs :confused: . The dogs on the 6th gear are probably rather small; and even much smaller once they're machined to a 45* (or whatever) angle. Is there weld on all fo them or just 6th? Will it shift into any of the gears? What do the forks look like?
  • 1 month later...
