randomrider Posted March 17, 2010 Report Posted March 17, 2010 i was just curious on how much would a good port and polish really improve the power? Quote
WINDYCITYJOHN400 Posted March 17, 2010 Report Posted March 17, 2010 Depends on what level of porting you go with Trail/MX/Dune/Race/FullRace. Also having parts that match the level of flow the porting will provide will help. But stock is mid 30's HP depending on the condition. Would almost double do the trick? Quote
bansheesandrider Posted March 17, 2010 Report Posted March 17, 2010 i was just curious on how much would a good port and polish really improve the power? It is the second best mod you can do to a banshee, with pipes being the first. Most guys do pipes first because it makes a big difference, and it needs to be done before ANYTHING else. Then guys usually do timing and compression mods because they are cheaper than anything else. After that it is usually reeds, porting, carbs, and then more displacement. Quote
KEVSWS6 Posted March 17, 2010 Report Posted March 17, 2010 Pipes and porting make the bike. Take your time on picking what you want. Quote
papa_smurf49319 Posted March 17, 2010 Report Posted March 17, 2010 Besides the simple mods such as pro flow kit or pods for the airbox, timing plate, tors elim kit, billet water impellar, the porting is one of the first things id do to a shee to make power, at the same time as porting i would also purchase the pipes id want to complement the porting. Also pancake bearing is a good idea for a reliability mod along with hd clutch springs! Cool head - nice to have if your planing on switching fuel grade in the future Carbs- nice to have but def not needed until you get up there in power Boost bottle- worst piece of shit you could ever buy! the list goes on and on! Quote
