chunky77 Posted February 26, 2010 Report Posted February 26, 2010 im changing out the stock clutch lever. what do i do with the parking brake wires coming out of the harness? do i cut them and run them together? thanks Quote
bansheesandrider Posted February 26, 2010 Report Posted February 26, 2010 im changing out the stock clutch lever. what do i do with the parking brake wires coming out of the harness? do i cut them and run them together? thanks Do not hook them together, when the park brake is set the switch is closed and the wires are connected. When the park brake is off the switch and therefore the wires are open. One of the wires is the ground circuit of the bike and the other wire is coming from the CDI box, so just cut them. When I removed the park brake from my wifes 97, I cut the green with yellow stripe out of the bike wire harness clear back at the plug for the CDI box and the other wire I cut it out where it spliced to the main ground wire in the harness. Quote
chunky77 Posted February 27, 2010 Author Report Posted February 27, 2010 Do not hook them together, when the park brake is set the switch is closed and the wires are connected. When the park brake is off the switch and therefore the wires are open. One of the wires is the ground circuit of the bike and the other wire is coming from the CDI box, so just cut them. When I removed the park brake from my wifes 97, I cut the green with yellow stripe out of the bike wire harness clear back at the plug for the CDI box and the other wire I cut it out where it spliced to the main ground wire in the harness. Koo man thanks for the help Quote
