HELLO EVRY BODY I HOPE YOU ARE ALL OK.
GUYS, DO I CAN MEASURE THE CRANK SHAFT IN ORDER TO RECOGNIZE STUCK , 4MM ,7MM AND 10MM OR THERE IS INFORMATION ETCH ONE BECAUSE I M PLANNING TO BUILD 4MM FOR MY STUCK BANSHEE! .
Wow, Saudi Arabia. Welcome aboard! Someone will swing through here and answer your question because I have no idea.
Welcome to the HQ! Are you wanting a 4mill crank? If so you can just buy a 4mill crank from any of our sponsors without need to worry about measuments of rods etc. Not sure what ur asking.
Brad
Yes dear I m from Riyadh in Saudi Arabia I m working as maintenance supervisor and I have nice friends from America and , Europe, we are all working in the same place , Thanks man I will tray to quote 4mill in Riyadh first .
Edited by banshee9090
i believe he wants to know what crank he has. maybe he thinks its a stock banshee.. or maybe he wants to know how to identify a 4 mil. r theyre numbers or letters etched on the crank....... i guess its hard to tell in a pic.. but just measure the stroke with a dial indictaor. 4 mil should be about 62mm stroke if im not mistaken
stock stroke is 54, so 58 is 4mill stroke...
lemmie go take a measurement that you can do just looking at the crank alone...
ok, if you look at the center of the rod pin by the outter bearing, the stock stroke center of the pin is behind the bearing. on a 4mill, the center of the rod pin is just about even with the top of the bearing. do you already know everything that is needed to make the 4mill work? domes/porting, or spacer plate?
Edited by AKheathen
Yes guys I really appreciate it, this information will help lots, tomorrow I will try to measure crank, connecting rod ,I will think about domes/porting, or spacer plate , one more time thank you very match.
