wadlesw96 Posted January 7, 2010 Report Posted January 7, 2010 ok my banshee will doesnt want to start very good in the first place takes alot of kicks then once it does fire up it will idle then you can rev it up once then it boggs down and dies it has a 2 in 1 carb and it is cold around 0 degrees. im new to banshees what is my problem Quote
98_shee Posted January 7, 2010 Report Posted January 7, 2010 What is your elevation, mods, current jetting, have you done a compression test, when did it start doing this? Quote
wadlesw96 Posted January 7, 2010 Author Report Posted January 7, 2010 im not sure about the elevation im in iowa tho. dont know the jetting either i just got it. mods are New top end .40 over with Weisco pistons and rings, new case halfs, hot rods stock stroke crank, Pro design Cool Head with 19cc domes, Barnett Racing clutch with stiff springs, 200 Watt Rickey Stator, FMF power core 2 silencers with FMF gnarly pipes, Trinity Stave IV 2 in 1 carburator kit and intake with matching carb, V Force Delta 3 reeds and cage, K&N airfilter. started doing this about a week ago Quote
Larry's Shee Posted January 8, 2010 Report Posted January 8, 2010 Not real sure, but it sounds lean. Need larger jet when tempurture goes down. Does it do this with choke on? Is fuel fresh? Quote
