banshee(911) Posted January 7, 2010 Report Posted January 7, 2010 im just wondering if its wise to go bigger.i have a well built 4 mill that runs some good time here and is there gonna b much difference in the times.(4 mill over ten mill)what are some good times on a well built ten mill?ive herd manny people say they wish they stuck with there 4 mill.either im gonna go bigger or go from a lightened stock chassie to a rigid Quote
locogato11283 Posted January 7, 2010 Report Posted January 7, 2010 a lot of it depends on setup, but there is a noticeable difference in power between the 4mm and 10mm cub motors. Quote
J-Madd Posted January 7, 2010 Report Posted January 7, 2010 Usually going to a better chassis will get you faster times than upgrading your motor on a stock chassis. I know of a 397 Cub that has run 3.72, but his complete setup only weighs around 220 lbs. Weight (and weight transfer) is everything. That being said, I ran 4.08 on my 4 mil Cub in a 315 lb stock chassis, and took me a 100 passes just to get in the 4.08s in a 250 lb strutted dune chassis. Quote
