What Size intake boots and filters do I need.
What is a good range of jets to have on hand for tuning at around 5000', as well what needles are a good idea to have on hand. This would be on a quad that has a cool head 19CC domes, +4 timing and T5's
Is it normal to have one carb set up with a choke lever, and one with a choke knob?
well, you can get away with stock boots and filters, but it's a little tight on the filters. i believe the size is 28-30, just specify your carbs when you are buying them. it is normall to have a knob and a lever, since the lever is hard to reach on the right. i take it you are running pods, so i would suggest 290-360 mains
