DallasGDub Posted January 7, 2010 Report Posted January 7, 2010 In the trails I like a 20 or 21 up front. (Depending on the back.) When I got 18's on the back, I run 20's. When I got 20's in the back, I run 21's. The read squats somewhat and that is a good thing. Clearance issues will really be determained by the area you ride. I know XC guys who run 22's+ in the desert. The tire to use should be judged on the type of riding. Quote
Mark M Posted January 7, 2010 Author Report Posted January 7, 2010 like i said i mostly ride trails and small riding areas near my house, some street riding too. Quote
DallasGDub Posted January 7, 2010 Report Posted January 7, 2010 I meant to say the type of terrain you ride. If your trails require more clearance, then go with 20/21. (stuff like stumps, rocks, logs, trenches, ext... you will need that exrta clearance). I really only see MX guys run 18/20 or 18/15. Quote
Ieat4strokes Posted January 27, 2010 Report Posted January 27, 2010 here is a pic of my old blue banshee with 18X11X10 fast trekkers on itp pro9 series. a smaller dia tire will accelerate faster and is less rotating mass when airborne. i wouldnt run anything smaller than a 20" unless you race motorcross. you will be dragging the back end around over terrain. if you do go with the 18" i would also stick with a 8" dia wheel. Now that is just plain sexxy! Quote
MikeNick Posted January 28, 2010 Report Posted January 28, 2010 Dude if your only trail riding get 20's. 18's suck on trails.. I constantly found myself getting my chain guard hooked on tree stumps or getting the rear stuck up on a rut like going up a hill. 18's blow riding everywhere except a track or a 100% flat and smooth ground. You will get annoyed with them.I've almost gotten throwed off my banshee when I had 18's..Was coming out of a turn on a trail and nailed it well it went down into a little dip and it was all tracked up and whatnot where people spun out....I cam to a complete hault when my skid got caught on the middle of the path on the dirt and yeah, I almost took a trip from all that momentum suddenly stopping.. Quote
feelsoright03 Posted January 28, 2010 Report Posted January 28, 2010 Hey just letting u know the blaster and banshee hubs are the same splines. U can put ur blaster tires on ur banshee just as long as u switch the tire and whole hub assembly. Its also 1 bolt and a cotter key compared to taking 4 bolts off. Make sure u pull the hub straight off also or else ur gonna have problems pulling it off. ~Teddy~ Quote
Wheelie Ripper Posted January 28, 2010 Report Posted January 28, 2010 I had 18's on my shee and like everyone is saying, my skid plate was getting hung up on everything. No fun doing a hill climb and all of a sudden the skid plate starts skiing and lifts the rear wheels right off the ground. For MX or smooth surfaces they are fine, but anything else they become a pain and will get you stuck everywhere. Quote
