Ok my shee seems to be pretty sensitive to loading up, is this normal? and when it loads up does it cause one cylinder to not run right? this happened to me twice today. can anyone tell me whats going on? thanks
Definately not normal. If I had to take a guess I would say your jetting is too rich or the carbs may need to be cleaned. If you post up your mods in the jetting section, along with what jetting your running now somebody should be able to get you close.
Also, what plugs are you running? The wrong plugs may also do that. Most people run NGKs in BR8ES or B8ES.
