Tf705 Posted December 30, 2009 Report Posted December 30, 2009 i have a stock stroke drag port done by herr. He told me to run 18cc domes and plus 6 timeing. i have a quality snap on gauge and i know its accurate. im only getting 140lbs. im in michigan so im pretty sure im sea level or a few hundred higher. i hear some you guys with drag ports with 170 to 180 psi. should i be higher or what? Quote
johnny boy Posted December 30, 2009 Report Posted December 30, 2009 Hate to hijack your tread but I have his aggresive dune port on 19 domes(stock stoke) and all i can get is 154pds.Ive tried a snap-on,matco,and a sears compression tester.All were pretty close (1-2 deg off).I'm at 414ft elevation above sea level.Kevin told me to run 20 domes on pump gas and I locked her first 20 mins out.Went to 19 and run straight 110 sunoco now.also have +5 timing.Have probaly 20-25hrs on her now.No problems what so ever. Quote
No Limit Powersports Posted December 30, 2009 Report Posted December 30, 2009 Have you checked squish? And how are you doing the test? Make sure that you are opening the throttle wide open and giving 10-15 good hard fast kicks. Quote
NickisGod Posted December 30, 2009 Report Posted December 30, 2009 im on your boat. im only 500ft above sea level 18cc domes on a 4mill cub and only get 145...... Quote
sleeper06 Posted December 31, 2009 Report Posted December 31, 2009 Something aint rite im at sea level 4mil cub 20cc domes 180lbs of comp Quote
tundish2800 Posted December 31, 2009 Report Posted December 31, 2009 Where are you in michigan? I have 175 with 17cc domes Quote
AKheathen Posted December 31, 2009 Report Posted December 31, 2009 yah, i have woo-hoo with 20's near sea level and in the mountains..... Quote
Tf705 Posted December 31, 2009 Author Report Posted December 31, 2009 i live in lower michigan. ive done a leak down test and it passed easily. i have done a squish test and it was where kevin should it have been, forgot what it was though. sorry to sound like a idiot but have not touched this thing in months. Quote
