01 BANASHEE Posted December 14, 2009 Report Posted December 14, 2009 (edited) hea whats up guys today i was out on the banshee and ripped up a hill then it started to die . i then decide to rip it apart to find the bottom of the pistion on the right side gone but the tops looked perfect any ideas why or what happened? also is my bottom end missed up now too ? it dose spin freely now dose seem bad Edited December 14, 2009 by 01 BANASHEE Quote
bansheekx Posted December 14, 2009 Report Posted December 14, 2009 hea whats up guys today i was out on the banshee and ripped up a hill then it started to die . i then decide to rip it apart to find the bottom of the pistion on the right side gone but the tops looked perfect any ideas why or what happened? also is my bottom end missed up now too ? it dose spin freely now dose seem bad I would say you had too much piston clearance and that let it rattle around till it broke the skirt off. You will need to split the cases to make sure you recover all of the broken piston . Quote
01 BANASHEE Posted December 15, 2009 Author Report Posted December 15, 2009 I would say you had too much piston clearance and that let it rattle around till it broke the skirt off. You will need to split the cases to make sure you recover all of the broken piston . okea so the bottom end should be okea right ? i did recover everything aswell Quote
FASTOYS Posted December 15, 2009 Report Posted December 15, 2009 okea so the bottom end should be okea right ? i did recover everything aswell Yep, must of gotten loose/worn on you and broke the skirt. IF you have all the pieces accounted for then your prolly ok. BUT if not then its a crap shoot as sometimes pieces can get lodged in the crank bearing oiling holes. Quote
VegasJeff Posted December 15, 2009 Report Posted December 15, 2009 Yep, must of gotten loose/worn on you and broke the skirt. IF you have all the pieces accounted for then your prolly ok. BUT if not then its a crap shoot as sometimes pieces can get lodged in the crank bearing oiling holes. nice to see ya back on here buddy,now back to work! Quote
