Jetting help PLEASE
333bbb333
So if we understand correctly, you are no longer using the 28s and now purchased 30 mm carbs?
I have been running 28 Mikuni Flat slides on my banshees for 20+ years.  Great carbs for trail, sand pits, seasonal road riding.  Just some thoughts:
#15 pilot is stock on these carbs, try size #20
Put air box and lid back on,  Remove snorkel and if you want drill a few holes in the airbox lid that's fine
Place the air screw at 1.5 turn out.  If your low end isn't good turn air screw all the way in.  If throttle response is just ok go up to a #25 pilot and repeat this process.  You should not need more than a #25 pilot.  There is no right or wrong answer on how many turns out the airscrew should be just leave yourself some room for fine adjustments.
No sir I had the 26mm and I went to the 30mm
7 minutes ago, Yaxy said:
Ok.  So I would try 30 pilot and 320 main jets.
FYI: I am not sure what the Outside Diameter is on the input flange on the carb thus you may have to open up the  hole in the intake boot.
 The engine side is 40mm and bell side 58mm but, I bought boots to fit bith sides already, ok ill try those jets and see what I get
11 minutes ago, Toybreaker said:
buy new boots, a vacuum leak will pop your pistons.
I put yamabond black on the boots and gaskets to be on the safe side, figured out the boots leaked air when i did the leak down test, how are the billet one piece intakes with built in crossover ?
