Hooptiee Posted November 12, 2009 Report Posted November 12, 2009 I bought a 93 Banshee and I'm having a issue. I was told the heads were decked, it has a hot rods crank, bored 10 over, has V-force 3 reeds, Toomey T5 exhaust with 320 jets,and a K&N Air cleaner. When I first bought it and got it hame it was blowing coolant out of the overflow line pulled the head and replaced the gasket because it was blown on both cylinder's. Put it back together took it for a spin. started 1st kick, idle to approx 1/4 throttle runs great after that it runs on the right side only(sitting on seat) did a squish band test and got .38 on the left side and .40 on the right. What would cause it to run on 1 cylinder after 1/4 throttle? or where should I start to diagnois this problem. Thank you for any help you can give me this is my 1st Banshee and I hope to get this straightened out Quote
00sheerzr Posted November 12, 2009 Report Posted November 12, 2009 try switching the plug wires and see if it only runs good on the left cylinder then u know its electrical , what do the plugs look like? Quote
