blanco25 Posted October 6, 2009 Report Posted October 6, 2009 I just recently bought an oversized boss radiator and was wanting to put clear hoses on it. Is there some special hoses or temp requirements that the hoses need to meet. I was wondering if some clear netted hose from ace hardware would work. The cheaper the better. any info would help Quote
Glamis321 Posted October 6, 2009 Report Posted October 6, 2009 ive heard of people using hoses from a hardware store that arent rated for the heat...they just change them out every season or so to be on the safe side. im not sure of any place that sells hoses that would be clear and rated for the heat. Quote
bkcustoms Posted October 7, 2009 Report Posted October 7, 2009 if you go to the attached link http://www.mcmaster.com/#tubing/=3ygluh it is a place called mc master carr. If you select on single line tube and the select the clear for color they have some tubing that it rated up to 500 deg which should be enough. I hope this help you. Quote
