I have a '01 shee, and i want to know if im running the best setting to get the best speed/torque results (sea level). This is still with the stock exhaust, wich will stay on for a while.
this is the setup right now:
- K&N Clamp on Filter (2)
- Dynojet jet kit Stage 3 (main jet DXP270, Needle groove #4 (from top to bottom))
- Advanced timing (+4)
- Front sprocket 14T
- Rear sprocket 41T
- VForce 3 (expecting)
How can i improve my setting to get the maximum results/speed, without losing to much torque? At this point that sucker
lifts the front weels in 4th gear with ease. Any tips are welcome.
- Rear sprocket 41T
4th gear wheelies on a basically stock bike? hmmmmmm
- Rear sprocket 41T
Your not really gaining anything with what you have done and wont until you ditch the stock exhaust. Pipes and a rejet should have been your first move.
i will disagree with that statement above and say the first thing you should do to a banshee is ditch the snorkel, lid, and put a pro flow on it, or ditch the box all together! Tors elim kit would be second!
