Have 97 shee That after a hard ride it runs hot the antifreeze comes out of the overflow tube not pouring just slight drip coolant conditon is good opened radatior cap and started did not shoot antifreeze out removed water pump cover started engine water pump is working great any help?also how would I go about testing it.
its green and coming out of over flow tubes
Mine has always done that, do you have a temp gauge. I thought mine was running hot too but it never broke 190. I use one of those radiator caps with a temp gauage in it.
If its boiling over its over 190. I believe 220 could be wrong though.
