tnbanshee43 Posted October 4, 2009 Report Posted October 4, 2009 Have 97 shee That after a hard ride it runs hot the antifreeze comes out of the overflow tube not pouring just slight drip coolant conditon is good opened radatior cap and started did not shoot antifreeze out removed water pump cover started engine water pump is working great any help?also how would I go about testing it. Quote
99bansheeboy Posted October 4, 2009 Report Posted October 4, 2009 are you sure its antifreeze ?? maybe its water and its expanding ? Quote
tnbanshee43 Posted October 4, 2009 Author Report Posted October 4, 2009 are you sure its antifreeze ?? maybe its water and its expanding ? its green and coming out of over flow tubes Quote
matt1 Posted October 4, 2009 Report Posted October 4, 2009 its green and coming out of over flow tubes Mine has always done that, do you have a temp gauge. I thought mine was running hot too but it never broke 190. I use one of those radiator caps with a temp gauage in it. Quote
2004LEBanshee Posted October 5, 2009 Report Posted October 5, 2009 Mine has always done that, do you have a temp gauge. I thought mine was running hot too but it never broke 190. I use one of those radiator caps with a temp gauage in it. If its boiling over its over 190. I believe 220 could be wrong though. Quote
matt1 Posted October 6, 2009 Report Posted October 6, 2009 If its boiling over its over 190. I believe 220 could be wrong though. Its not boiling over, it just dribbles out a little now and then. Quote
