Here's a stupid question, I got my first set of K and N pod filters and was just wondering if they make some type of bracket to support the back of the pods so they dont get knocked loose on a hard landing or is this not a problem?
ive had problems with my pod filters falling off while riding. usually not on hard landings, mine tend to just vibrate themselves off during a ride. i havent seen any brackets for them, but you could fab something up yourself. I am working on getting an airbox for mine so i dont suck in anymore sand :ph34r:
Nothing to work on, Your Banshee came with an airbox that works just fine. All you need is a proflow adapter and K&N inside the airbox and you will flow the same as pods with the lid off.
well the guy i bought the bike from had the pods on it already so i dont have the stock airbox to use. ive seen some pretty cheap on ebay so i might pick one up from there
My pods rest on the x-member of the frame. If you want to draw up a bracket that will suit your needs, I will manufacture it no problem.
-JD
