The only hoses that go to your carbs come from the petcock on the fuel tank. The lower radiator hose goes to the water pump, (right side) of your motor and the upper hose connects to the front of your head. The smaller hose coming from the radiator will connect to the top of the head (not the overflow, it won't fit there). The smallest hose coming from the radiator, up near the cap, is your overflow tube. I point it at my head pipe so when it overflows I can see the steam off of the pipe. For the crank case vent hose I just run the hose out the back of the motor. I tuck it between the rear motor mount tabs and just let it hang off the back of the motor.
