Hey guys I was just cleaning my quad that has some mods to it and noticed the expansion tank was empty. I filed ot with some water and let the quad get up to temp the water stayed crystal clear so I popped open the rad, it was full to the cap. I started to follow the lines and noticed the bottom line just vents top one is hooked up to the rad. is that right? Wouldn't I just be loosing coolant then? The quad doesn't seem to overheat. So where is it supposed to be hooked up if anywhere?
Looking from the front of the quad, The top right hose from the rad goes to the top port on the expansion tank. the top left hose goes into the top of my cool head the mid left hose goes to the front of the head, bottom hose on the rad goes to the water pump
Its not a recirculation tank,you dont even need it.I take them off all bikes except ones that run at the track.Dont worry its plumbed rite
So just make sure the rad is filled up and I should be fine? Thats good to hear. I've been beating this thing for the last three days and was like shit it must be overheating!
