Ok I have a stock clutch cover with a mattoon insert and I had it powdercoated the temp of the oven cracked the seal and I need to replace it. Its an epoxy type sealant at least thats what it looks like to me anyone know what they use?
We've used Moroso AB epoxy.
There is a Devcon type pour in epoxy that works ok.
I got tired of the epoxy leaking, etc...I got mine welded. Best thing you can do is weld those covers in.
From the fluid and the vibration, IMO, sooner or later they're gonna leak.
ya I should of welded it up before PC was done but before that I never had any problems with it sealing so I guess if I can get another year of two out of it by resealing it it will work for me thanks
Clean/grind the old epoxy off.
I had to redo mine when the epoxy leaked. It lasted about 1 trip and blew the side cover out after a few passes. I didn't do a good enough job cleaning off the old epoxy.
Weld it, get it re-powdercoated. You won't have any more issues!!!
It took a while for mine to leak the first time. Once It did....it was all over after that.
