bansheecaptain Posted August 12, 2009 Report Posted August 12, 2009 I just put a noss head on my bike with 20cc domes and it seems to have a bit more knocking sound and I check the squash and it seemed fine unless I did the check wrong. Just asking if its normal or is there something wrong Quote
blowit Posted August 12, 2009 Report Posted August 12, 2009 I just put a noss head on my bike with 20cc domes and it seems to have a bit more knocking sound and I check the squash and it seemed fine unless I did the check wrong. Just asking if its normal or is there something wrong Higher CR motors will tend to have a bit more pop to them. Now an actual knock is a problem but if you are jetted right with 0 to +4 timing on pump fuel, you should be fine. B Quote
bansheecaptain Posted August 12, 2009 Author Report Posted August 12, 2009 Ya my jetting was a tad rich before I put it on and I asked on here if I need to change jetting and they said no so I would assume my jetting is still good. And ya I'm running +3 timing Quote
bansheecaptain Posted August 12, 2009 Author Report Posted August 12, 2009 And I run 94 octane and ride around 1200ft above sea level and they said it was fine to run 20cc domes. Quote
Drewski Posted August 12, 2009 Report Posted August 12, 2009 well theres your problem, you checked the squash not the zucchini Quote
bansheecaptain Posted August 12, 2009 Author Report Posted August 12, 2009 Yep. What would be a good way to double check that. To check the plugs or pull the head apart or is there a short cut Quote
SAVAGE420 Posted August 12, 2009 Report Posted August 12, 2009 well theres your problem, you checked the squash not the zucchini Drew, that had me roaring man :laugh: Capitan, just watch this and do what he does. No need to have the head off. Quote
brugal Posted August 12, 2009 Report Posted August 12, 2009 well theres your problem, you checked the squash not the zucchini LOL :yelrotflmao: :yelrotflmao: :yelrotflmao: Quote
bansheecaptain Posted August 12, 2009 Author Report Posted August 12, 2009 Would alittle bit of slop with the piston cause that kinda knocking sound Quote
