heres my setup,t5 prodesign foam filter,160psi,4 timing stock airbox with slotted lid 25[pilot]280[main]. Heres my problem banshee was fine until today, took it for ride and the left pipe felt alittle hotter than the right.Check everything took carbs apart clean them out it idles fine, revs fine all through the power band.Sprayed everything with carb cleaner no change in nothing but you can still feel one pipe hotter than the other.Carbs are sync the bike feel great is just the difference in temp on the pipes, doesn't feel like it has a air leak everything looks good need help before going to beach on sunday.
