XxMeltIcexX Posted June 22, 2009 Report Posted June 22, 2009 I'm trying to find an EZ Purge Block, I've seen them before but can't find them anywhere. If someone has a different idea for purging please post pictures. I need a new way to purge instead of quick disconnects or pulling off the lines. Thanks Eric Quote
KaosBanshee44 Posted June 22, 2009 Report Posted June 22, 2009 What's wrong with the quick disconnects? I just pull the lines from the carbs everytime. Never heard of what your talking about but would like to see. Quote
Bansh-eman Posted June 22, 2009 Report Posted June 22, 2009 I like the quick disconnects. Very simple to use. Although pricy for what they are, they work great. Just make sure you get the ones that have shutoff valves on both sides, so when you disconnect they dont flow alky all over the place. Quote
rubberneck Posted June 22, 2009 Report Posted June 22, 2009 sorry about the crappy cell phone pic, but if you zoom in on my tank, you can see the aluminum block attached to the fuel lines on my tank. basically allows you to shut off the petcock, hook up your purge bottle and purge the bike. Nothing to disconnect This one came on the tank when i got it, dont know where to get another. Quote
KaosBanshee44 Posted June 22, 2009 Report Posted June 22, 2009 I like the quick disconnects. Very simple to use. Although pricy for what they are, they work great. Just make sure you get the ones that have shutoff valves on both sides, so when you disconnect they dont flow alky all over the place. Yeah i've seen quick disconnects for 60 bucks a pair. So if you want one for each fuel line your gonna spend 120 just on disconnects which is ridiculous. sorry about the crappy cell phone pic, but if you zoom in on my tank, you can see the aluminum block attached to the fuel lines on my tank. basically allows you to shut off the petcock, hook up your purge bottle and purge the bike. Nothing to disconnect This one came on the tank when i got it, dont know where to get another. I had a hunch that's what melt was trying to explain. It's a simple idea the hardest part is trying to find it. Quote
87sheerips Posted June 22, 2009 Report Posted June 22, 2009 I usually just make a mess. Unhook the lines from the carbs, drain the alky back into the alky tank. Hook up the lines, put gas in the tank, purge it. Wow, I need to come up with something a lil better lol.... Quote
shanYE west Posted June 22, 2009 Report Posted June 22, 2009 I normally use one disconnect (Can get them in the pars unlimited catalog for like 20bucks..) Put the disconnect on the outside line. Shut the fuel valve off and disconnect the line.. then plug in the othe disconnect with a long drain tube.. Drain the tank... hook the line back up and put about .5 gallon of purge fuel in and run it out... done.. no mess.. Also.. I dont use disconnects with the shut offs.. I just hold a towel under it when I sperate the connect. Quote
XxMeltIcexX Posted June 23, 2009 Author Report Posted June 23, 2009 Any of you guys have pics? I just want to set it up one time instead of buying 6 packs of line to try multiple combination's lol Quote
Darthwall Posted June 24, 2009 Report Posted June 24, 2009 it looks like it would'nt be to hard to make just get a piece of aluminum probably 1"x1" by maybe 2" drill the center out on one side about 1 3/4" get some bungs to thread in and on the end put a valve to connect to the purge tank so when the purge tank is not hooked up you shut the valve from your pump or pingle then the fuel goes straight through the lines Quote
rubberneck Posted June 24, 2009 Report Posted June 24, 2009 it looks like it would'nt be to hard to make just get a piece of aluminum probably 1"x1" by maybe 2" drill the center out on one side about 1 3/4" get some bungs to thread in and on the end put a valve to connect to the purge tank so when the purge tank is not hooked up you shut the valve from your pump or pingle then the fuel goes straight through the lines yeah, you could easily make one that way. only thing nice about this one is that it is machined one piece so it is very compact and light. Quote
Darthwall Posted June 24, 2009 Report Posted June 24, 2009 did you have that one cut or did you find it for sale somewhere my example is just what I made out in your pic and it makes alot of sence Quote
rubberneck Posted June 25, 2009 Report Posted June 25, 2009 did you have that one cut or did you find it for sale somewhere my example is just what I made out in your pic and it makes alot of sence I bought the tank from tim (azcustoms) and the block was on it. it is inscribed as ezpurge. dont know who made it. Quote
moneybags Posted June 26, 2009 Report Posted June 26, 2009 I usto see them on ebay all the time. Quote
flyhighprerunner Posted June 26, 2009 Report Posted June 26, 2009 sorry about the crappy cell phone pic, but if you zoom in on my tank, you can see the aluminum block attached to the fuel lines on my tank. basically allows you to shut off the petcock, hook up your purge bottle and purge the bike. Nothing to disconnect This one came on the tank when i got it, dont know where to get another. Just another question....WHY DO YOU HAVE THE PARTS IN THE LIVING ROOM AND NOT ON THE BIKE? Quote
moneybags Posted June 26, 2009 Report Posted June 26, 2009 haha Could be the bathroom Austin. If that is the case I could make a guess. Quote
