Alright Banshee Guru's, I trying to put all my coolins system lines back on and have forgotten where they all go. It's just all the breather lines and overflow shit I need help with. Which ones do I need to keep and for the others where do they go? There is one at the filler neck of the radiator, where does it go? One coming out of the water pump area, where does it go? The two overflow bottle ones? There is also a line on the top rear of the engine cases, is that a crankcase breather? Please help me!
The line coming out of the side case by the water pump t's into the line coming out of the back of the case they are vents.The one coming out of the top of the radiator goes to the overflow bottle,the other line from the bottle dumps any excess coolant on the ground.
