cpetersen Posted June 15, 2009 Report Posted June 15, 2009 One exhaust smokes more than the other one. Neither is excessive but I was thinking I should adjust the carb on the one that is not smoking much to match the other side. What are your thought? Thanks in advance. Quote
LiftdT4R Posted June 15, 2009 Report Posted June 15, 2009 Many things that it could be. It could just need a simple adjustment/cleaning. Or if the pipe on the right smokes more it could mean that your crank sels are starting to go and your burning crank oil. How does the bike run otherwise? The bowls on the carbs could be swapped from side to side if it has been running kind of shitty too. Quote
cpetersen Posted June 17, 2009 Author Report Posted June 17, 2009 Many things that it could be. It could just need a simple adjustment/cleaning. Or if the pipe on the right smokes more it could mean that your crank sels are starting to go and your burning crank oil. How does the bike run otherwise? The bowls on the carbs could be swapped from side to side if it has been running kind of shitty too. She starts on the first kick. Idles perfect. But sometimes bogs down when giving her gas on a drag race. Quote
