Handyman Posted May 31, 2009 Report Posted May 31, 2009 Ok so I've been pondering this for a while now and have done some research but have not found any solid answer....I have a Cheetah PV motor and when it needs to be rebuilt i was wondering if i can bore it from 68mm to 72.. to make it a 535cc Cheetah PV motor....i know I will need a new crank and trench the cases but that's still cheaper than building one from scratch.... Quote
2001Stroker Posted May 31, 2009 Report Posted May 31, 2009 It can be sleeved up to 75mm. But, to make it a 535, you need a 10mil crank, 73mm bore, porting, and some custom domes. Quote
Handyman Posted May 31, 2009 Author Report Posted May 31, 2009 Yeah I know I'll need a 10mil crank...Ok so it is 73mm....i wasn't sure if it was 72 or 73 so I just made a guess...what kind of custom domes will i need?? Quote
Bansh-eman Posted May 31, 2009 Report Posted May 31, 2009 You might go to ATVDR and ask this. I am not too sure if you can just re-sleeve it to fit 73mm. I want to say that I read somewhere that the transfers are not the same, and that you should just buy a set that are already setup from CP with the size bore you want. I might be thinking of Twister, not sure. I just remember this coming up a long time ago and seem to remember someone saying that you Quote
Blewbyu Posted May 31, 2009 Report Posted May 31, 2009 You might go to ATVDR and ask this. I am not too sure if you can just re-sleeve it to fit 73mm. I want to say that I read somewhere that the transfers are not the same, and that you should just buy a set that are already setup from CP with the size bore you want. I might be thinking of Twister, not sure. I just remember this coming up a long time ago and seem to remember someone saying that you?re better off going that route. Correct. Buy yourself the 64 cast cylinder. If yours is for a stock stroke, it will not work. And they don't sleeve the cylinders they bore and then re nikasil. Quote
