Exactly what the title says, here are my mods and such:
Stock cylinders
19cc Cool Head
+4.5 timing
28mm Mikuni carbs
VForce III reeds
Pod filters
FMF Fatty Gold pipes and Turbine Core silencers
I run on the dunes, mostly sea level in Michigan. Mid 70's to upper 80's temperature wise.
Right now I have a 340 main jet and it seems rich, does that sound too big to you guys?
Thanks!
Stock cylinders
19cc Cool Head
+4.5 timing
28mm Mikuni carbs
VForce III reeds
Pod filters
Thanks!
what fuel are you running? round or flat slides?
Mikuni TM28's, flat slides. I was running 93 octane prior to putting on the Cool Head, but will be running race gas now that my compression is higher.
Also, I am using a set of reed spacers as well.
Edited by ChippewaTSI94
