yamahaman244 Posted May 28, 2009 Author Report Posted May 28, 2009 ya I will maybe that head is worped alittle pit then u can just shave it right Quote
KEVSWS6 Posted May 28, 2009 Report Posted May 28, 2009 ya I will maybe that head is worped alittle pit then u can just shave it right Yes you can mill the head. Dont forget to check the cylinder decks. Quote
yamahaman244 Posted May 28, 2009 Author Report Posted May 28, 2009 i just toook it for a ride and i warmed it up and everything and you know weere the jug and the exhast pipe meet to come out of the jug it is blowing oil and stuff out of there i wonder if that seal went out or not but anyway i warmed it up and took it for a ride it was smoking some white then after a while it dint some at all barley and then it started smoking again???? Quote
kawa110 Posted May 29, 2009 Report Posted May 29, 2009 i just toook it for a ride and i warmed it up and everything and you know weere the jug and the exhast pipe meet to come out of the jug it is blowing oil and stuff out of there i wonder if that seal went out or not but anyway i warmed it up and took it for a ride it was smoking some white then after a while it dint some at all barley and then it started smoking again???? How much oil was blowing out of ther? I run my bike real fat and it doesnt blow oil out of the front exhaust ports. Are you loosing radiator fluid out ther as well and not just oil? you just put new gaskets and seals, did you check all the mating surfaces for damage/scratches/cracks? Quote
KEVSWS6 Posted May 29, 2009 Report Posted May 29, 2009 Your pipes are just not sealed up. Get new exhaust seals and use high temp RTV. This will seal them up tight. The oil coming out is normal when they leak. It makes a big mess after every ride. Quote
yamahaman244 Posted May 30, 2009 Author Report Posted May 30, 2009 Ya it is just blowing alittle oil out but enough to make a mess idk it can be blowing out antifrezze idk how u would be able to tell and another thing after I ride it awhile and shut it off it seems to start hard but when it cools down it starts in one kick Quote
yamahaman244 Posted May 31, 2009 Author Report Posted May 31, 2009 Ya I'll have to do that um idk it seems to rum good how far do u think it would go if it don't have anytifreze in it Quote
