I was riding over the weekend, mostly random drags and hillclimbs, when I downshifted, a little too early, and my banshee just start making a weird noise, the exhaust pipe 'fell'from it original postion, and it stopped running. I can get it to run now but it sounds fucked up and i dont kknow what it is.
HELP!!!
well first things first, if your ass and your ears tell you some things wrong for gods sake listen it will save you loads of cash in the long run! Next what do you mean when you say the exhaust fell from it's original position? :huh: I would run a compression test on both cylinders and see if you hooked a ring or maybe damaged a piston before you do any more riding!
Edited by patrickkomar
HELP!!!
what do you mean by fell. More info needed. Your post does not really explain much.
Yep need some more specific info. What does the noise sound like? Fell?? No more running till you tear some of it down. Start with the head and look at your pistons to check you rings. From there I would make sure one of your crank bearings didnt fail. But what ever you do, NO more running.
When I first built mine, on the first ride, I blew a crank bearing and it screwed my rings up on one side. Luckly I shut it down as soon as it happened. Put a new piston and crank and have been running it for over two years now (on that same bore). If I would have run it anymore I probably would not have been so fortunate.
Edited by boneyardbanshee.
holly shit! 1 more for the AK. so was that pipe leaking alot of exhaust? what jets are you running? what fuel are you running? check your compression. check the reeds- is one of the carbs spitting fuel out the backside?
where do you ride? have you checked out jim creek lately?
I was at jim creek last weekend there is alittle mud from the rain, other than that it is good to ride. one of my moms friends went to the glaceir and said it was really muddy.
