Today, i installed a override on my new 4mill engine. It's an override 1-5,N down dunable from wcr.
I follow the instruction on the box ( 1min on first with pulled clutch ...)
I try it a couple of past on my home test track and a couple of the, the transmission shift by himself a gear. What is the problem???
I think it's possibly my clutch... For today, i use them with a standard clutch, no rdz spring or lock-up.
What could cause this problem?
thank you
bansheeqc
thank you
bansheeqc
A lockup won't solve that problem, more than likely the shift shaft adjustment isn't right...check that.
With an override, you really should pickup a lockup.
Check with Kevin Herr, HJR Racing for an undercover lockup.
You don't have to buy or mod your stock clutch cover, it fits underneath it.
Hello, while were on the subject of overrides,
would some 1 be able to upload a couple of pics of a stock trans and an override so I can see side by side what the differance is?
My drag bike has an 1-5 override and I dont really want to split the cases just to see what it looks like.
cheers, Paul
1sick6,
I don't have picts side by side but the differance is the way the dogs on the gears are cut. Also the Shift rum gets moddified. If you have a duneable there is springs between the forks to assist when shifting.
