So i have power jets on my 40mm hv lectrons, how do you know if they are working? it does not seem like the fuel is going up to the jets from the bottom of the bowl? in the line it looks like its only going 1/2 way up the line? but i am not looking at it when i am running it? any ideas?
when you wic the throttle you should see the fuel level jump up.. but it wont fully reach the PJ.
so what do i do correct this problem?
There is no problem as long as what I stated is happening.. thats the way they are. the fuel wont reach the PJ's by sitting there. if you wic the throttle and the fuel level jumps in the line, then the PJ should be functioning correctly.
so how exactly do i tune them? never understood if i should turn them all the way up or what?
You will want to start w/them wide open, And go down from there. When I am trying to jet my bike I make 3 or so passes, check the plugs, close down the pj's half turn at a time(if it's rich) and repeat.
Do you know how to read alky plugs?
how do you read alky plugs?
That is a good article, but is nice to have pics. Are you going to be at Silver Lake this weekend Joe? I can give you a hand if ya like. I will be at WMSD on Friday and the dunes Saturday and Sunday(Woooohoooo LOL!).
Unless you are trying to get every last bit of hp out of the motor, you can always start with them open, then start closing them by 1/2 a turn or so until the engine runs clean. Make sure the cylinders aren't getting too hot. This is a very safe way to tune, but of course reading the plugs will get you closer to max potential hp.
thanks bro .. ya i will be there saturday.....
