hey guys im hopeing you can help me. just picked up a 95 from a friend for cheap because his brother ran a tank of 20:1 fuel through it. the problem is that it sounds like the right cylinder isn't firing or is misfiring. there is a lot more smoke coming out of the right then the left and it is no where near as hot as the left pipe. thanks
Welcome to the HQ. You need to look at the plugs and see how they look and prob.replace them.The carbs may need to be synced also.If you have a compression tester,it would be a good idea to get those #'s. Do that stuff and go from there. Also,how does the airfilter look?And what are all the mods to her.1 more thing,PICS please.
k&n filter vforce reeds fmf fatty pipes thats all i know of. the plugs a relativly new he said he just replaced them. airfilter could use a cleaning. with my crappy compresion tester im getting 130 on both cylinders. you dont think the 20:1 gas did anything??? is there a search option so i can find out how to sync the carbs?
the right one is on the right
THose look pretty bad. they shuld be a orang yellow color and not be all black and nasty. to much fuel. are you running regular fuel or premium or race gas? perhaps its not liking ethinol in the fuel if your running regular pump gas. id try runing some race gas to see what happens
a dirty air filter would cause this?? i only have one filter 2 into 1?
no just maybe rich.It needs to be clean anyways.I was talking about syncing the carbs.Did you get the vid?
yea i synced the carbs clean the air filter. still doing it. could i be burning the clutch/trans oil?? i filled it the other day when i got it and just checked it and i seemed low but could be from running it im gonna check it in about 30 min or so.
right side smoke more often than not points to one thing...
blown crank seal, do a leak down test to confirm the engines holding pressure before you start chasing your tail trying to fix a bunch of stuff thats working correctly...
