oneslowshee Posted April 17, 2009 Report Posted April 17, 2009 i hear everyone mention on this forum how important the tune is... i wanna know what everyone is meaning by " tune" and what they are doing.. thanks Quote
shanYE west Posted April 17, 2009 Report Posted April 17, 2009 i hear everyone mention on this forum how important the tune is... i wanna know what everyone is meaning by " tune" and what they are doing.. thanks Tuning a bike is more then just jetting.. its finding the right compression, timing, carbs and pipes, ect.... and making it all work together. There is also "chassis tuning" wich is pretty much the same thing.. Getting all the parts to work their best together. Quote
oneslowshee Posted April 17, 2009 Author Report Posted April 17, 2009 Tuning a bike is more then just jetting.. its finding the right compression, timing, carbs and pipes, ect.... and making it all work together. There is also "chassis tuning" wich is pretty much the same thing.. Getting all the parts to work their best together. the only thing i am wondering is carbs you can jet, but everything else is pretty much stuff you buy? unless i am missing something/ thanks for helping me out fouledout.. i have my 421 with shear pipes and 40 m hv lectorns want to get the most out of it,... Quote
shanYE west Posted April 17, 2009 Report Posted April 17, 2009 you still have to buy the right parts.. then you still have to tune them.. Timing, compression, dome designs. Its finding the right combo with all the parts to find that sweetspot. Some motors like high timing, low compression.. while others are oposite. My motor really liked high compression (195lbs) and high timing (13 degrees on the plate) now this setup isn't going to be optimal for most people.. but it was for me. Your builder can give you a idea of where to start then you gotta take it from there and just keep trying different stuff. I guess thats the best I can describe it. Quote
dragbanshee98 Posted April 17, 2009 Report Posted April 17, 2009 you still have to buy the right parts.. then you still have to tune them.. Timing, compression, dome designs. Its finding the right combo with all the parts to find that sweetspot. Some motors like high timing, low compression.. while others are oposite. My motor really liked high compression (195lbs) and high timing (13 degrees on the plate) now this setup isn't going to be optimal for most people.. but it was for me. Your builder can give you a idea of where to start then you gotta take it from there and just keep trying different stuff. I guess thats the best I can describe it. could not have put it any better than that :cool: Quote
oneslowshee Posted April 17, 2009 Author Report Posted April 17, 2009 could not have put it any better than that :cool: so where would you guys recommend i start? let me list what i have 421 cub timing is @ 8 40mm hv lectrons converted to alky set up by packard shearer sm oof +8 swing arm 12 paddle ultra lites lock up override cut by K&t anything else you guys need to know i will tell you but i am curious to know if you guys think i am doing anything wrong? i am not sure on the compresion i should check that. when i spoke with packard he stated that i would not really gain anything from porting the cubs and to try them out first because i am new to the whole drag setup. he said i should be just over 100 hp and he said at most will be 110hp Quote
dragbanshee98 Posted April 18, 2009 Report Posted April 18, 2009 so where would you guys recommend i start? let me list what i have 421 cub timing is @ 8 40mm hv lectrons converted to alky set up by packard shearer sm oof +8 swing arm 12 paddle ultra lites lock up override cut by K&t anything else you guys need to know i will tell you but i am curious to know if you guys think i am doing anything wrong? i am not sure on the compresion i should check that. when i spoke with packard he stated that i would not really gain anything from porting the cubs and to try them out first because i am new to the whole drag setup. he said i should be just over 100 hp and he said at most will be 110hp i dont know if it is just me but readin this u seem like you are bein kinda vague... but from what i read you are lookin for the best way to set up or tune your bike??? i would say start with are you doing just strict drag racing??? what are you familiar with tuning certain things, if anything, on a banshee??? motor, etc... Quote
