last summer i noticed coolant evaporating in the head, and saw 2 hairline cracks on both sides.
so today i started to get her ready for the summer and decided to try to fix it.i pulled the head off and one side the crack is pretty ugly. the other side i can weld at work but the other i thank is not repairable.
BTW. the top half of this motor is from a RZ350 and the head says YPVS on them (yamaha power valve system)
so does anyone know where i can get a head for this? would a stock banshee head work or do i need the rz350 one?
thanks in advance
The power valve is not hooked up. I do not have the eletronics for it but I'm looking for the stuff on eBay. I bought the bike with this stuff already done.
Maybe I will have to repair it.
Also if anyone has information on where I can find the power valve stuff that would be awsome
here are the pics
this doesnt look good! detonation?
other side looks ok tho
i pretty sure the carb is a DG keihin pwk
Edited by Boominrick
Just looking at the bolt pattern on the head, it looks very similar to a banshee head. Anyone have a stock head laying around they can send this guy? Talk to dave at noss machine, he might be able to help you out with an aftermarket head.
measure the holes on 1 cylinder. front to 1 rear is 95mm center to center. front to each middle is 57mm c-c. middle to middle 78mm c-c. i have one sill installed, but i'm gonna put my powerhead on soon. looks like yours is freeze damage, from the look of he coolant passages, and where it cracked.
yep, looks like she froze and cracked.. i would inspect the rest of the coolant system for cracks (cylinders, radiator).. the rz head is different from the banshee head.. if you do not have the electronics for the powervalve system, i would get some banshee cylinders and get rid of all your problems.. a good set of ported banshee cyinders will do great.. good luck.
i know the size and coolant hose is different, but will it bolt up?
nope. it has a different sealing surface shape.. i am almost positive that a stock banshee head will not work.. i have done my share of research on converting over to a rz setup.. needless to say, i still have the stock cylinders.
