I no I will probably have to get a picture to describe this but here goes..Where my motor bolts to the rear of the frame, there is one metal spacer plate on one side of the actual motor mount and I need to know if there should be one for each side or not. I couldn't find the piece I was looking for in the motor teardown section of the manual or on a Yamaha parts fiche.
I thought what I needed was #5 on this list but now I' thinkin no...I'm fuckin lost..Someone who has takin one of these out and put it back together b4 help me!!!!!!!!!!!!!
http://www.powerpartsplus.com/pages/parts/...d/2/Yamaha.aspx
i cut mine out of some thing bicycle tire.
So you traced them out on a bicycle tire then cut them out of that???
I may just buy some but the little fuckers are like $9 bucks a piece, or thats the cheapest I have found them...blahhh..This sucks
Well I took a piece of rubber mat that was the same thickness as the one spacer I had and traced/cut them out of that and used one on every corner, maybe that will cut down on some vibration..
lemmie know how that works out.
