quadicted Posted March 15, 2009 Report Posted March 15, 2009 What do you guys think would be the best reed setup for a stock motor with DMC 916 pipes, twin air filter, 280 jet needles and 25 pilots? I mostly ride trail rides and some mx, but i plan on having a mid range port job. Quote
AKheathen Posted March 15, 2009 Report Posted March 15, 2009 What do you guys think would be the best reed setup for a stock motor with DMC 916 pipes, twin air filter, 280 jet needles and 25 pilots? I mostly ride trail rides and some mx, but i plan on having a mid range port job. boysen rad valve, or chariot performace reed cage (which uses boysen pedals) :thumbsup: Quote
quadicted Posted March 15, 2009 Author Report Posted March 15, 2009 boysen rad valve, or chariot performace reed cage (which uses boysen pedals) :thumbsup: Are they top end powered? I would like to get some mid power out of my bike since the 916's are top end pipes. Quote
AKheathen Posted March 15, 2009 Report Posted March 15, 2009 Are they top end powered? I would like to get some mid power out of my bike since the 916's are top end pipes. they do have topend, but are softer for better bottom/mid. switching to midrange pipes as well will get you closer to what you want, though. Quote
quadicted Posted March 15, 2009 Author Report Posted March 15, 2009 they do have topend, but are softer for better bottom/mid. switching to midrange pipes as well will get you closer to what you want, though. So no way i am geting a litle gain in the bottom/mid just to ease the kick on high rpms? Quote
AKheathen Posted March 15, 2009 Report Posted March 15, 2009 So no way i am geting a litle gain in the bottom/mid just to ease the kick on high rpms? don't get me wrong, they will give more low-mid, and top, just not as much topend as something like a vf3. i'm just saying that pipes and porting are the biggest dictators of power range. some timing advance should help out in the low-mid, aswell. only like 30 bucks for the plate, too. consult your builder on it, too Quote
quadicted Posted March 15, 2009 Author Report Posted March 15, 2009 don't get me wrong, they will give more low-mid, and top, just not as much topend as something like a vf3. i'm just saying that pipes and porting are the biggest dictators of power range. some timing advance should help out in the low-mid, aswell. only like 30 bucks for the plate, too. consult your builder on it, too Thank you very much for the info. Quote
